Advance steel 2013 - calculation report nodes
  • Thread starter Thread starter Xythras
Xythras
hello to everyone I am approaching this program, I would have 2 questions not if simple:
with an installation in Italian you can create a calculation report of the knots in English?
in the reports are also reported the formulas used according to the normative code that you choose for verification, these formulas besides of course that in the legislation are described somewhere in the program? for example in the documentation, in case you want to make the report more clear with a short legend of the various coefficients.
Thanks for the answers.
Hello xythras,
I don't think that's possible. I had the need to change other things, and I solved in a very trivial way:
I installed as in another car in English and worked like that.
you can download the license on one side and mount it on the other and, at the same time, you can manage the model quietly.
Bye.
hello thank you for the answer, if you understand using the nodes calculation form, could you tell me what your experience was? we at the time when I wrote the message we tried to calculate the nodes according to normative aisc we met problems.
hi xythras, I will tell you that I have made some small reports, but I do not speak of aisc but of ec3. were solved with the first service pack issued, so I never cared about anything else.
Thank you, can I ask you if there was a incorrect reading of some geometric dimensions? some values were taken equal to 0 or in some rare cases the values taken were not correct.
Hello xythras,
Have you checked the values set in the project tolerances? Maybe if he writes 0 as a value it's the fault of those.
