Tristus
Was it a job done with autocad? a normal office plotter or a printer would have had no problem. It is clear that when industrial machinery comes into play, the speech changes. Anyway, I never said that autocad is free from small sins. If then the error arrives for too much imperative of the designer, then any file can be a problem regardless of the program that created it. autocad perhaps requires a little more attention due to construction lines, points, etc. etc. all stuff that should be placed in a dedicated layer to freeze or erase altogether. in the case of that designer, it was not noticed, especially in consideration of the machinery that had to interpret the elaborate.who had prepared this layout had not been worthy to clean it from hidden lines, tangents, and other leaving only a few axis and lines of the geometry in sight, but had done a nice select everything and put everything on the thin layer that then had become a block on vatelapesca layers (in fact something was not printed because it was finished on an unprintable layer).
about catia, in the case of the example made before, that of the ramp of stairs, in case you notice that the number of steps does not return, the program really allows you to change only the number of steps (i.e. simply a numerical operation) to return the modified solid? I repeat and reiterate, I have never used such parametric programs, even though I have seen some tutorials. I felt like a very powerful program.
