aggiornare swbrowser.mdb
cacciatorino
after updating swx from 2009 to 2010, no longer works the creation wizard holes, says the default database is not updated to the correct version 14.10. is there the way to update the db instead of using the default one that swx proposes me for 2010?
The problem I'm putting on is that I assume that db contains the predefined holes of my client that I wouldn't miss, but instead migrate to 2010.
in the 2010 installation DVD there should be a toolbox update program, it should go well for you too, I remember using it a few years ago, if anything check ... hello
You're right, the file is under the dir.
c:\programs\swx corp\swx\toolbox\data utilities\updatebrowserdata.exe
Thank you so much!
