agreement
  • Thread starter Thread starter Cla
Cla
I'm getting nervous, I'm trying to sweep a part in a certain way...if you see the image in the annex I should risucire to collect on the side a cone trunk with a "cylinder" to elliptical section...I made the cone trunk with a revolution and the "cylinder" with a blend with a sweep where I would take the elliptical section and I'm going to the wrong with
Hello! !
the sweptblend function (or sweep with blend or blend with sweep) takes the tangence in "enter" and/or "exit", but requires surfaces that are adjacent to the section.
(in your case, the cone trunk cannot be used as a reference to tangency )
soluzoine a)
flood the trajectory of the sweptblend, and create an additional section
smaller, which allows to find an intersection with the cone trunk, with which to collect it later
solution b)
you can create tangent curves and create "handed" fitting surfaces,
which then integrates into your solid modeling (solidification )
thanks for the explanation. . .
we say that I have successfully undertaken the solution to...another domandina, with the feature blen limit can close a defined surface with 4 curves arranged at 90°? I tried to create 4 curves that develop at 90° the one from the other (I hope to be explained decently) and selected in order the 4 curves (the chains seem to call her the command) in order to create a kind of cone trunk in order to realize a hump in correspondence of the first half. .
if I have not done wrong you can also use the variable section sweep.
p-h
I remember a couple of years ago that I used a command in which you could give a perimeter trajectory... now I miss...? ! ! ?
is the limit blend ( once was the blend / contours)
curves must be chosen by direction (a sense, 2 curves)
the 90°, the other 2.
the curves must be touched at the extreme points, and you can manage tangenza/curvatura/normal plan / superfici
without me starting a new discussion. ..how do I make a section that automatically updates...that is by moving the section plan and seeing my model update?? I think we can do this. At least I was told, but I didn't know how to do it.
Maybe talk about the dynamic section.
If this is what you are looking for, the topic has already been dealt with, the dynamic section, as well as dynamic editing, were introduced with the wf5.
