p= lxxw/ b 2
I hope I have been exhausted, if there were errors, I invite you to report it to me, the calculation was carried out empirically based on material tables thanks to the collaboration of the next
http://mhscrane.com/education-center-overhead-bridge-cranes.html
the formulas used for calculation are those of a beam supported with a long dot load x:
being that the axes of the cart are two and the load is divided equally on each axis it is necessary to make calculation for both forces on axis wheel p.
or with x over half beam:
with this type of analysis you can optimize the section of the structure by lowering the weight compared to the calculation with a single concentrated force.
