criV
Hello!
I hope I'm in the right section. I use autocad 2012 and I have to do this design
but I have 2 problems:
1-in the vertical part, I did in 2d the vertical arc profile only that when I extrude it turns out empty and not full! how can I do? ?
2-in the lower wall then there is that "s"-shaped fitting but I just can't connect the two solids. How can I do that? ?
Thank you so much!
but I have 2 problems:1-in the vertical part, I did in 2d the vertical arc profile only that when I extrude it turns out empty and not full! how can I do? ?
Thank you so much!
