aid for quota
  • Thread starter Thread starter valeria_emme
I still do not understand why in the table I can only see the supermetals relative to the front floor:confused:
From this point on, my judgement is like a sports bar advisor... I said this I saw that in your model, forced to move faces you arrived to a thickness of the base, along the division line, of 33 mm to reach a thickness of the finished 15 mm... :eek:
I, that a fusion crude must have a volume that is almost double the finite, I don't even believe if I see it.
Hi, I'm rotten, I hope this discussion about drafting quotas will help me.
when I quote a particular with the command "sequence rate", then can I make every independent quota?
I'm trying to get better off with the attached photos.
- I carry out my "sequence rate" as in photo1.
-I would like to get the photo2 result, so that each share is independent from the other, in practice "exploding/eliminating" the existing bond between them.
Isn't that maybe you got the wrong section?
Mar
