aid on rendering of laboratory project
  • Thread starter Thread starter nandos89
nandos89
Hello, everyone. I am a student in building engineering-architecture is so far no problem, I follow the design laboratory course and the professor as conclusion of the course has assigned us a job to carry out with 3d study. to me was touched a project of a marble workshop, I made the base with cad car and then import it with 3d studio, the problem arises here. I can simply put the materials but always with little results as the professor explained this program the last lesson for 2 hours is especially asks that this work is perfect unfortunately I did not find anyone who can help me. I make my last appeal on this site, is there anyone willing to give a system in any way to my work? I can send it by email with the screenshots that have been given to me by the prof for the project. I look forward to your reply
apart... all the story, which is better to fly over.
Why don't you put the pictures? (You have to deliver some renders? will the assessment take place on those?). so we can help you all.
you have to deliver 4 renders of this factory, and in addition a video over 10 seconds. with a camera that onquadra is blessed factory... I already have the project ready on auto cad if you want to place the file but I don't hires to fix it on autocad:frown:
but then you didn't start work in 3ds!??:rolleyes:
I thought (and I hoped) that you needed a good fit to make.. . !
here we can all help you and give you some advice... on how to fix in 3ds... and how to set up to start making the video.
So....post the renders...and we give you some advice!:wink:wink::wink::wink::wink:
the job I have already started it but I don't think that the renders that I have done are in pietosa condition I can post file 3d study directly
I do not see the file as I think it is created with 3dstudio 2010 and here I have 2009. As for the title now I change it and I'd beg you next time to use more significant titles " desperate help" doesn't mean anything.
Maybe post qulache image of your work reached so far so we see where to improve the renders, not hope that someone will do the job for you because you fall badly.
However, it seems strange that a teacher explains a program like 3d study in two hours and demands perfect jobs, there are courses for 3d study that last months and from there to perform perfect jobs it takes years of experience, so, or your teacher is a deficent suit or you do not have the right story or the perfection that he requires is based on the design technique and not so much on the final renderings. . .
yes the version is the 2010 fact is that he in two hours explained how to put the materials, how to import a file from autocad, how to make a reder and finally how to create a video. stop. first the program he claims it in English, so if I never used it even in Italian as I can get it in English. I don't want to talk bad about the professor because he is a very good person in himself, but to explain it is not his really cmq thing here are some renders.
3d studio from version 7 (100 years ago) does not exist in Italian, so even if he claimed it in Italian, there was no...
then, the idea is this, the way explained 2 things on the cross and with those you have to do, so if it has claims you can also respond badly.
with autocad modeling we are, but I recommend you read this site http://www.ecosystem3d.com/corsi/moduloa/prog3dstudio.htm It is made for max 6 and 7 but for the basic functions it is still very current, it is well done and divided into chapters so you can read what you most interested, but my advice is to go gradually at a time. from there you can take hints to improve your renders.
I know that I should answer him badly, but unfortunately I still have two subjects in front so let's forget. how to make supregiù as quality? How is it? very poor? What can I fix tomorrow I have a review and on Monday the exam I don't even have much time
Well, there's a lot to work here. and you can't expect any of us to explain to you a whole program like 3d studio considering that even your professor did.
However, you should understand what your professor means by "perfect" and how long you have to do it.
the advice I can give you is to take a nice look at the help of 3d studio max, especially the tutorial section.
then turn on the web and you will find many tutorials on texturing, and how to deal with an external rendering with mental ray (the rendering engine included on 3ds max).
If you have difficulties with English (although it should not be so seen that you are engineering student) use the 3d study in Italian so much you will present pictures and a video.
you have to spend time understanding, trying and getting... and you will see that it will be a good satisfaction at the end.
good work and make yourself feel ahead if you have any issues or want more specific advice.. we are here available.
If you want, I'll tell you what to place, but if you don't have the basics, you'll have trouble understanding. . .
- There are no shadows, from which it is deduced that there are no lights. place at least one "direct" light with "overshoot" active to generate a little shade more or less with direction to the point of view and approximately with iclination at 45°
- you're definitely using a render engine that doesn't take into account global lighting, so you'll have to create a series of "good" lights with low "intensity" to simulate it in too dark areas
- the objects to which the materials are applied need "uvwmap" in order to have a control of the "tiling" of the map
- to have the rillievo effect you should use a gray scal map in the "bump" channel of the material
- you should contextualize everything by putting a background in the "environment"
I don't think you understood, but if you look in the online guide "f1" of 3d studio (in English, there's no other way) and look for the terms I put you in quotes find what they mean and what they are (stay here to explain them in a post, it would take me all day).
I repeat that the site I have indicated is great and already good ideas you have them, even there some research you can do.
I read now that you have time until Monday.. .
Well, you have a nice weekend to work on it.
Sorry guys, but what about the materials? Can't find many for example, asphalt? Or cover a tit with tits? ? ? ?
