aid piece
  • Thread starter Thread starter Vito18
Vito18
Hello everyone, I am new in modeling 3d and I am not minimally experienced in the use of modeling software(I at this time use rhino8), I would have a problem, I can not correctly effetttuate a connection between two solids(the one highlighted by radius 2):
I don’t know what function you need to use, the only one that seemed to me approached is “fillet surfaces” that gives me this result:
but in this way it does not cover the entire surface, if instead the "extend" box in the "fillet surfaces" function I have this:
That's not good anyway.
I don't know rhino, but did you try to make the two-way connection first and then the other one?
