align views in different sheets
  • Thread starter Thread starter Biggmetals
Biggmetals
Good morning colleagues,
for my boss' laziness and/or, however, a better aspect of the boards of a project I find myself sometimes to lose an infinity of time to align each drawing on a sheet with that of the sheet after.
I am not able to provide a concrete example for confidentiality but I make you a sketch on paint to make you all perhaps a little lighter.
Immagine.webpin very short the x and y coordinates of the red "points" (center of the drawings must be equal between a table and the other so when you go to scroll in a unique pdf the central design of sheet 1 and of sheet 2, having equal measures, do not move but change only the other two views. for now I manage where possible with the functions or however aligning everything together so that the origins of both solids are centered but it is really a workman that takes away me a lot of time.
I've been looking for an automatic solution for a long time, but I've never found anything.
that you know there is a way to align them without being mad by measuring the distance from the edge of the sheet for the x and y coordinates?
- You can use the rulers.
-or drawings within the sheet a reference on a non-printable level, draw a reference point on a non-printable level in the view and, to the eye zooming, overlap and block the row
-or after doing well the first right button sheet on the label of the folio>, again right pulse on the label of the same sheet> paste
often using axiemi I find more comfortable this escamotage, all lined at the origin (using the plans) and replacing the model is all aligned (or changing configuration you want)
I thought there was a command like "sheet line" we say but I never found anything even in the guide.
solid goods
