alinole ansys upgrade
  • Thread starter Thread starter AmrGmar
AmrGmar
Hello, everyone.
I have to perform the modal analysis of a tree with two cast discs using single-dimensional elements.
I shaped the tree with beam188 elements and disks as concentrated masses with mass21 elements inserting as real costants mass x y z and moments of inertia.
both the knots of the beam188 element and the mass21 element have 6 gdl.
to verify that I should find so many natural frequencies as the total gdl, for simplicity I shaped the tree with 4 knots two end and two with the characteristics given by the two disks inserted in the constant real. I should therefore have 24 frequencies (in a free analysis)
the problem is that I do not understand why the result provides a total number of 60 frequencies.
I don't understand why since there are only 4 knots with 6 glds per knot.
Thank you for letting me down.
hi, the problem lies in the definition of the beam188 element, in fact if you set the keyoption(3) =3 the program autonomously creates two internal nodes to the element.
then get the following scheme:
No...
at the end the number of knots become:
- 4 knots defined by you (n)
-2 knots int x 3 elements = 6 additional nodes
the total knots then becomes 10 x 6 gdl = 60 gdl
also considers that the results of the analysis can be trusted only for the first n°gdl/2 modes of vibration since beyond this value the error increases considerably.
No...
Thank you so much
