Iceyes93
Hello, everyone. I'm bumping into a geometry that I can't work because I can't set it on alphacam.
I use a 5-axis machine.
In the images I attached the view 3d, the profile section and the processing. How can I do that corner? I have currently worked the tilted parts with the tilted cutter with parallel axis on the tilted plane but rightly stops me when it meets the inner corner of the frame. So I stay on the corner a square not worked. I have this problem because initially they had to be 2 pieces divided and in that case simply the cutter could make its path until the end of the shaped list. currently it is not possible because I would go to carving the list to it perpendicular. the braking therefore should carry out a rotation regarding the internal edge maintaining its inclination but I do not know how to set it on the software.
Currently the only solution I found is to carry out surface processing in those points with many passages of a round tip but the working time is much longer than to be able to make a single pass with the tilted milling.
I tried to explain the problem but it's not very simple.
(in the image of the finished processing there is also lack of the internal rounding because I am waiting for the milling radius to be communicated to me).
I thank in advance those who will give me an inspiration on how to act
