alternative program data transmission heidenain heidenain
  • Thread starter Thread starter rinato
rinato
Hello, is there any way to transmit the *.h programs to more milling machines without having to switch continuously between one machine and the other (connected to ethernet) in the tncremo program?
I was thinking of using a second program (if it exists), i.e. organizing myself with a sw x machine. Is that a stupid idea? I tried with 2 tncremo sessions, but conflicts arise.
Thanks for the help, reborn.
heid is the only company that offers a product like tncremo and you want to give up? ?
If conflicts arise with more than one active link is a problem to be solved as it does not constitute the norm.
Okay, so is it likely to be the ethernet to improve? Now as now, with a tnc320 and tcn510, when I change the machine to which to transmit, the prg. never remembers the last folder of the machine to which mi ricollego and stops at the beginning of the "prompt", so you can say. "The last directory..." is already active, but it seems to work only if I return to the last m.u. used.
However, I do not intend to give up, only to have an alternative to keep on "in parallel".
Thanks anyway for the answer, as soon as I have the hardware technician, I submit the problem to him.
Greetings, reborn.
forgives the delay of response.
I have no knowledge or experience of 310, so take my considerations for what I am (...considerations).
with 426, 530, 620,640 the tncremo has no problem to support the transmission (even simultaneous) on multiple machines; the other day I had 6 at the same time connected to the same pc. Only thing the software does is to warn you that it is already active more than one session.
I don't know how to hypothesize a cause to your problems.
an alternative is to use one of the "usual" data transmission software (e.g., etc.) but, frankly, just because the tncremo does it as master I on heid I have not really used them (and I don't know anyone who does it).
Thanks to you too, Filipino.
I'll try something again when I have time to devote.
At worst, I will break the balls to the custonservice. . .
hi, I wanted to know if you solved your problem, otherwise you can try with sercom transmitting to all cn at the same time ... up to 44 m.u.
can also use wired/wireless moxa converters to transmit and receive
Hello hosvir, thank you for your interest.
no, the problem is, technically, still at the same point, but it can be said that it is being solved by itself, since now the m.u with the tnc320 has in memory 4 prg of number for work in series with the masquerade pieces, and the mask is not even disassembled because x those pieces, instead of going in "phase out" as pavented by the customer, the numbers remain supported and tend to rise.
if and when we need another m.u. I will have to remember this discussion (honestly I had forgotten :sleep:, many are the other things that I have to follow ).
Greetings, reborn.
