alternatives 2d to geomulate
>Iceman<
Good morning to all,
I know very well (and it is convenient) the geompiatta command where you can create a flat view, of solids 3d, but there is an equal... for the 2d?
I explain: I have a dwg that I can't handle and I would like to create a sort of "photography" of what I see.
the inquisitive dwg, presents blocks, symbols, etc. but to me just a simple set (block) of lines, circles, etc.
thanks in advance
if you like an approximate test result with wmfout (which creates a wmf file) and then use wmfin that matters it in another file.
the truetype texts are lost and the resolution of the circles is based on the zoom in phase of export.
you could export pdf and then import pdf...
or print in a dwf and then insert it as subject object. . .
the goal is to import it in lightened revit. is the plan of a 130mb plant.
:roflmao: :roflmao: who knows how much trash there is inside. to me a file with 35 boards a0 (121 thousand objects between beads, blocks, tables, pictures etc.) weighs 17mb... to make 130mb I should have 300 tables a0 in one file.
purge nada? Ole? (I imagine... )
in fact but very comes from solidedge. is its 2d converted to dwg
