altezza column
  • Thread starter Thread starter Marcusbox
Marcusbox
How do I set the height of an architectural column?
I am on my first model with revit, I need to insert external columns ranging from the floor to the third floor ceiling. I uploaded a circular column from the library, but I can't change the height.
Thanks, bye.
the height of the columns or pillars is deliberately altered by the panel 'instance property' setting the base level and the upper level and eventualities the relative offsets from the same.
bye:
ah I was looking for in instance and type parameter while those options were directly in the options bar.
Okay, thank you.
