analisi termica con wf5
  • Thread starter Thread starter wonderboban
wonderboban
Good evening to all,
I am thinking of learning to use wf5 because I have the urge to add to the processing cad 2d also of the 3d elements.
the first project that I need to need a thermal analysis of the dissipation.
It is an extruded aluminum to which I have to apply about 30w of heat and see how it behaves, how it disposes the heat and if the surface is sufficient.
Do you want me to?
Thank you in advance.
No wonder.
if you have the package fem (pro/mechanica) now called creo simulate you can definitely do it, wf5 is just the cad.
Do you want me to?
No wonder.
if it's just this is a calculation you can do by hand. :wink:
In any case I want to try it as well as I create the simulated package.
