analysis cfd fluent and patran
  • Thread starter Thread starter dariodario32
dariodario32
Good evening to all, I am a new member to the forum. I address myself to you since I just started using cae programs, as support in writing my thesis. I reach the point:
My goal is to calculate the stresses on a wing immersed in a motorcycle field. I managed to finish a cfd simulation test in fluent, calculating the force agents on the wing. Now I wonder how to export the distribution of pressures calculated in fluent so that we can insert pressure loads on the geometry precisely in patran.
you need to create a text file with coordinates in xyz and pressures
from patran then import the text file and create a spatial field.
then create a pressure and value from the spatial field.
to say it is easy to do it a little less. .
wave
