analysis fem axioms welded promech. wf4.0
  • Thread starter Thread starter Dancan
Dancan
Hello, everyone. , I have some problem doing the fem analysis with a welded set the steps I made are:
- assigned the material
- assigned constraints
- assigned the load
- made meshatura
I can't start the analysis, basically the icon with the 3 squares that brings in the file menu - new static ..., is not active with a set, while if I have a .prt everything works perfectly, ... at this point I ask you:
is it possible to do the fem analysis of a welded set with pro|mechanica wf4.0?
What steps are there to do?
I have never taken proe in hand but a guide within the program and the tutorials do not exist? something will be written about the analysis of together. normally in modelers the steps are the same part or together that they are.
Hello dancan... I have your own problem.. .
Did you manage to solve it?? Is there a way?? or can't you do the analysis of a proe set? ?
