Creeperhead
Hi I would have a problem with patran (I'm approaching this type of fem software recently) and asked me to perform a structural analysis on a component I had made on catia, the point is that once set everything and launched a static linear nastran analysis does not generate the file. xdb. are there fatal message on .f06 that I cover you under.
please refer to:
msc_doc_dir/doc/pdf_nastran/nastran_library.pdf
1 july 23, 2019 msc nastran 11/14/17 page 1
0 n a n a n a n a n a n d s y s t e m p a r a m e t e r e c h e c h o
0
$ sysfield=scr*(raw=yes,buffio=yes,wnum=16,wsize=16mb) $(c:/msc.software/msc_nas
$ sysfield=dball(raw=yes,buffio=yes,wnum=16,wsize=16mb) $(c:/msc.software/msc_na
nastran buffsize=8193 $(c:/msc.software/msc_nastran/20180/conf/nast20180.rcf[6])
$ msc.nastran input file created on july 23, 2019 at 11:36:47 by
$ patran 2018
$ direct text input for nastran system cell section
$ direct text input for file management section
$ direct text input for executive control
$ linear static analysis, database
1 july 23, 2019 msc nastran 11/14/17 page 2
0 n a s t r a n e x e c u t i v e c o n t r o l e c h o
0
sol 101
cend
1 msc.nastran job created on 23-jul-19 at 11:18:21 july 23, 2019 msc nastran 11/14/17 page 3
0
0 c a s e c o n t r o l e c h o
command
count
1 $ direct text input for global case control data
2 title = msc.nastran job created on 23-jul-19 at 11:18:21
3 echo = none
4 subcase 1
5 $ subcase name : default
6 subtitle=default
7 spc = 2
8 load = 2
9 displacement(sort1,real)=all
10 spcforces(sort1,real)=all
11 stress(sort1,real,vonmises,bilin)=all
12 begin bulk
*** user fatal message 108 (sca.mdsolver.obj.inputfile:inputfile::read)
the input stream data file c:/users/user/desktop/studiofattibilit�345/studio345.bdf does not exist.
*** user warning message 209 (sca.mdsolver.io.accessaccess:accessaccess::isechosortrequested)
no stream input file has been converted to its binary form using streamtobinary.
the echo data returns will all be false.
*** system fatal message 501 (sca.mdsolver.io.accessaccess:accessdatabase:
pen)
error 1 occured while attempting to open database c:/scratch/studio345.t9000_58.ifpdat.
*** system fatal message 3001 (ifpdr)
the input data block named ifpflag at position 1 does not exist.
user information: this error is caused by one of the following:
1. the data block was never created.
2. the data block was deleted.
3. the data block is specified on a type statement in the current subdmap or a higher subdmap
but the current qualifier values do not match
the qualifier values of the data block(s) on the database.
user action: 1. if you are executing an msc.software supplied solution sequence and not using the
alter executive control statement, then check for bulk data and/or case control input
errors. if no errors can be found, then contact msc.software client support.
2. if you are executing a dmap program not supplied by msc.software, then for debugging purposes
insert statement diagon(20) before the module shown above.
programmer information: the fist number is 101 and subroutine is ifpdr
0fatal error
1 * * * end of job * * *
please refer to:
0
$ patran 2018
0
sol 101
cend
0
command
count
3 echo = none
4 subcase 1
6 subtitle=default
7 spc = 2
8 load = 2
12 begin bulk
0fatal error
