animation along the path
  • Thread starter Thread starter Tantocattivo
Tantocattivo
Hello everyone,
I have a "small" problem, I have to animate a box along a path, so I used the path constraint and so far everything ok. the problem lies in the fact that I want the object to "run" that I know for 30 frames, then I want to stop it for 15 frames and then restart, how can I achieve this?
thanks for the help
we say that I solved by creating a key when I want to stop it, then I copied it and moved it to the frame of the partition, the problem was that I didn't know how to copy the key, in fact I still held the shift + drag for copairla, but I couldn't find commands for copaire cut the keys etc. cmq would be interesting the same know how you would do it.
ciauz
the measurement unit is time (seconds) not frames.
frames are the number of photos sw does per second.
the lower the number the more the animation becomes coarse.
because in your case one is half the other, then we talk half a second.
I'll get you an image.
use I would put the timebar until the component has to move and move it.
I move the timebar again where the component should restart and put a time key and move the bar to the bottom and move the component.
It's easier to make than to explain.
thanks for the answer,
the concepts were clear to me, I had only the problem of not knowing the command to copy, cut, paste, drag etc keys in 3ds max. then I asked how the other 3dsmax would do because maybe I expected someone to tell me that there is a panel where you can edit the keys more comfortably.
cmq thanks
