animation of a collection
Antar
Good morning to all,
I am trying to create an animation to "give life" to the lantern of leonardo da Vinci, which I would like to put in my portfolio.
When I put all the pieces together, however, I don't recognize the rotary pairs, so I can't put on the engine servo that should operate the mechanism.
Would someone know how to tell me if there's a way to make my rotaoid couples know?
It's my first animation.
If someone is willing to help me, I would be grateful and I would also share the drawings, once completed and working :)
a clarification.
I didn't know if the mechanism module, moving it by hand, works. Is it just a problem of animation or even constraints?
I think it's a problem of constraints because when I put the pieces together, I don't get out, for example, the possible rotating pairs that in the mechanism are there.
it doesn't even work by moving it manually
The axieme is made with educational creo..
is not openable with creo for commercial use.
unless you make a step, but with the step you lose the characteristics of cinematism.
I also doubt that with the educational version there are limits of use of the mechanism application.
