animation solidworks folding sheet
  • Thread starter Thread starter Cuspide
Cuspide
I wondered how it is possible to create an animation of a part (constituted by a simple sheet) that is bent along a line, of a certain angle.
the study of the movement does not change the properties of the part (that is, there are no keys to these properties), but there are strategies that allow to "add" the problem?
hi sperx, yes this video I know but I can't understand the fundamental passage. he selects the curved part of the sheet (obtained during his design with the command "split padding"), but the sheet selection displays the fold angle as a simple quota (which then can simply associate with the coupling value). to me instead nothing happens and clicking instead on change function the value of the corner can be only numerical and not functional. Am I wrong?
Do you make sure you have some mistakes in selecting the quota of the coupling, wrapped to me by problems, you have to do 2 or 3 times double click without opening the property of the coupling...I don't know if I explain, I'll attach you a file made by me hope you have version 2023?
Yes, the error was in the selection.. double click and the quota is visible. The only thing is that now I have a new problem that I would like to understand how to "manage". in the file prepared yesterday the quota is visible and editable, but in the file that is doing today retracing all the steps, I can make visible the quota but when I try to change it tells me that it is read-only. How do you handle this kind of unexpected?
Never happened to me, do you have a pdm and the file isn't checkout? alone reading? or maybe you used some other option to make the folded part. without the files I find difficult :)
solved. I don't know why but the share entered read-only in the file part of origin and so the property obviously found me in the file of assemblies. Thank you for your help.
