Annoingculations
  • Thread starter Thread starter lattu
lattu
a bit I'm ashamed to write this post but I can't solve a trivial but very annoying problem.
on the import of new files and creating new objects I constantly visualize the vertices of the triangulation of the faces and the thing affects the fluidity of the scene and the render:
2015-11-30.webpI know for certain that it is not a file problem but it is a software setting. I switched all the display options a bit but I can't find the right one.
10 points to help me
3d studio max design 2011 (do not comment on version :rolleyes:)
Hello lattu,
if we talk about editable mesh try to select the edges and make them invisible
no are solid, however I solved by setting directx 9.0 instead of 10.0. thanks the same
It's nitrus' fault, changes the directx, indeed, you should use nitrus, but I believe in 2011 it was not yet indicated by that name...
(You solved it, I saw it after writing!!!sorry!!)
nitrus is a viewport display system introduced in the 2012 or 2013 version of 3ds max. allows you to have a better preview with realistic shading with shadows and reflection, ao, etc.
if you use mental ray, there is a beautiful script that allows you to have an instant preview of rendering in viewport of excellent quality.
if I can allow myself, I recommend to switch to version 2016, for usability and management of the file, even if the old mode of viewport displaying an image in the viewport for the recalc of a model, you have to use zoom & pan! I hope to have been helpful.good day!
Okay, thank you.
Unfortunately, for economic reasons, I am still at 2011 :frown:
for those who want to deepen here a nice link
