tele
Good morning to all,
I am novice both of the forum and of the product ansys that I am beginning to use for a thesis work.
doubt 1
from what I have understood until now ansys allows two ways of modeling:
a)definition nodes and elements (example beam and links)
b)definition of areas and volumes and subdivision in mesh according to the element attributed (plane, solid, shell)
in the case of a beam element to 2 knots, I must specify the cross-section, but then also coming at the bottom of the calculation I always get only monodimensional views (it always holds a line). possible does not exist a way to see it in 3d? or should I model it as volume and treat it as a solid element?
doubt 2
if you want to model two solid elements with a bond between them (no matter which) in the hypothesis that it has two solid elements to 8 knots how to proceed?
doubt 3
until I stay in the plan I have no reference sys issues.
when I plan to create a simple spatial travail with beam elements, at the time of introducing the loads does not recognize the direction of these, although it always inserts the same face of application and same value (e.g. negative).
I hope someone more experienced can enlighten me. . .
thanks to all and good day
doubt 1
doubt 2
doubt 3
