CarmineR
Hello everyone,
Someone would explain to me how to create and use an image to be applied on a surface (with aspects and colors) so that a completely perforated sheet is simulated, so that you can see what is under it.
the option of directly making a perforated sheet is to be discarded because already doing 200 holes employs 1 hour to generate them and the surface that I would like to cover would use more than ten thousand holes.
suggestions?
Thank you very much
suggestions?
Thank you very much
