application incorrect aspects/materials - error or bug?
lorenzostella91
Good morning.
I'm loading you a video capture to best express my problem. as you can see, in an attempt to apply the material/look to a face of a solid body/part in change part the result is as having applied a simple color (the texture of the bricks does not appear), while if applied as in the second passage from the project shaft through "materials <non specificato="">" everything works perfectly, with any material/ appearance. In my sector, it is very important to manage materials (wood) and their orientation. summing up:
- need to correctly display materials like wood by applying them to drag on the desired face
- the problem arises on all materials/species
- the problem also arises working only on one part, without being included in any set
- I did repair the software through installation cd without solving
- I'm freaking out!
link for video download:</non>http://www.mediafire.com/download/k2ldn9jbgksz1j7/2016-03-03-1146-03.flvHow do I/I have to proceed? do you think it is settings or a bug?
Thank you in advance!
Good morning.
- I'm freaking out!
that texture is one of the few you do not see if you do not have a graphics card that supports the real view and even with the enabled rv is only schematized.
If you try to make the render you will see it applied.
nb: you can apply textures to faces even without changing part when you are in a set, unless 2011...
Moreover, do not make confusion between material and material to render.
Thank you for the answer!
I exposed the problem because this behavior did not happen before updating the pc to w10! however I solved:
in the options menu to select file paths, I linked the sw folder contenting aspects/materials in the custom aspects and everything goes smoothly.
Thank you for your help!
