apply a material on a polyhedra mesh
  • Thread starter Thread starter elisa mariposa
you are a scientist:biggrin: doking:hahahah:
doking it is obvious that in the file there was of the other the layers were turned off there was no need to make the rendering to notice the plant.:biggrin:
Then I don't understand what you did quietly?
Let me understand thanks.
I didn't notice the layers:redface: I will be too fused at this time
cad.system with the file posted by elisa mariposa tristan process to convert polyhedral mesh into solid did not work, I copied the sofa to another file and the same process was successful
passes to another area of work. the classic interface won't be there forever, you better get used to it.
I installed the plugin, but how does the program open? I have the classic view!
doking follow the advice of tristan is right, better than you get used to.:wink:
even if I do not think they remove this possibility, which in my opinion is very convenient to change configuration according to their own needs.
30092012135700.webpin classic mode of autocad you cannot doking use this command, because it is directly inserted in the new tab display mode.
Who tried this command among all? :biggrin:
