apply material
  • Thread starter Thread starter Fenice1974
Fenice1974
Hello everyone,
I pray to be a self-taught and I attend little forums because of the time at my disposal, unfortunately do not do a job that allows me to use this porg. "fall v5" "I try to change work" and that's why I don't attend this magnificent portal.
today I wanted to make a right design to learn the commands, but at the end of the solid when I go to give him a material in the properties it turns out that I gave the material but to video does not make me the "redering" that is does not change its initial state.
I kindly ask if someone knows how to solve this prob. At first he told me that the library was read-only, I don't know how to turn off the "read-only" item and give it a path to the material library.
I thank in advance all those who will give me an answer.
Hi, I just put a green paint on my exactness, but the window that opened showed me the library but it was written that it was read-only. going on the properties of my particular makes me see the paint on the piece but to video no.
Thank you for answering me.
I think it's okay (I don't have the software available right now). as mentioned above you must switch the display (after you put the material) into "shading with materials"
Thank you, forgive my ignorance but how do you do it?
by shading you mean the various possibilities of seeing the solid?
Sorry to have some patience. .
Thank you 1000. As soon as I turn on the PC I try.
but I can explain why. There is a logic I am in a standard condition I see my piece in 3d I apologize I don't know how to explain it.
thanks for the info.
there are go types of display depending on what you want to see at that time (hidden lines, without edge, dotted etc.).The application of the material greatly weights the system
Okay, thank you. I thought having a good pc like mine didn't fall into these probes..? ? ?
Thanks anyway for the time dedicated to me.
