apply properties of my.dwt to customer.dwg and update
reggio
Hello, come back with another easy question ... ;p
I wonder if it is possible to apply the properties (dimscale, quotas, text, fonts, lines, restraints, ..) of my.dwt (a custom dwt)
to any file as it can be an incoming file from a customer using other settings and then apply and update dwt customizations on the latter.
What do you say?
I don't think so.
in these cases we give all the documentation from the customer (dwt, ctb for print verification, carts and squares, possible blocks, technical specifications at least of the use of layers).
then if the disegnno was made on its own template I believe that the only one is to copy all entities in the customer's template and with various commands to do everything
commands that can be used:convlayer convert existing layers to target layersqselect select entities based on filterscorrisprop copy the properties of an entity to another where there are in common
I don't think so.
hi massivonweizen, thanks for the answer
... I understand ... I will continue as I do now: I cover all the customer design, take off in my new white sheet, empty quota and then brush copy properties on all the customer quotas, regarding axes and hidden lines, if serve I will use my that I will find myself among those of the customer...
unknown command "convlayer". press f1 for the guide.
.. eh? :confused: ... ah, "the brush"!!! :
if it is only for quotas try this method:
renounce your quota style like that of the customer
copy customer quotas in your design
renounce your quota style as previously
In theory, I did a quick test, it should work.
instead of the test convlayer uniscilay
good suggestion :d I tried ... in fact I do not know which is the fastest method ...
uniscilay is accepted, but I didn't understand what he did...?? select a layer 1 object then one layer 2... and then? nothing changes...
uniscilay is accepted, but I have not understood what it is
combines and moves layers between existing ones.
example:
you have the axes under the axe client layer (which has its color, the line and the thickness) and you want it on your axes layer (which has its color, the line and the thickness different from that of the customer); of these layers you have about ten, some of which you gather in one.
with this command you do it in a few steps; with a script you are really few seconds... If I find you,
test this sequence:
uniscilay
write n (name) to choose from the list of layers present the one to change
refer the command if you need to bring another layer to the target layer otherwise press Enter
write n (name) to choose from the list of layers present what to bring those chosen
you must appear a confirmation pop up
the axe layer is gone and all the entities under that layer have the axe proproities
It seems to be snoring but you're little bit of a hand
example:
test this sequence:
uniscilay
You really know them all!
