april file v20 con la v18
  • Thread starter Thread starter sediuko
sediuko
Hello everyone, I would like to know about there is some way to open files created with if v20 with v18 without converting into step or other formats so as not to miss all the processing!
Thank you all.
First of all, I think you'll be immediately dicked by the moderator for non-presentation, given your first message, then for what you asked I'd say it's not possible.
Welcome.
then, some info:
1. read the forum rules
2. we present
3. you use the search function and you would have found some discussions on the topic (we told it and laugh that you can not go back, but if you use the st ....)
I ask vein to all for not being introduced, I have no excuses!! ! !
Anyway, hi, I work for a company that uses solidedge, and I found myself in the problem of having to open v20 files sent by customers, but here in the company we still have v18. Now that you tell me so there's little to do if I don't send the files to step iges or anything, but the problem remains that I won't be able to change them! !
thank you and apologize for failing! ! !
Greetings from Uncle
if you have the classic you can change them with direct modeling commands, however in any case you lose the association with the table. However if you have to make a v20->v18 test with parasolid rather than with step. Unfortunately v18 does not matter the jt (export only) with which you could also transfer the anagraphic information besides geometry.
