marco12ccc
Hello everyone, I am new in the forum.
I started using revit recently and I found myself in front of the first problem.
I should make a square arc section cable tube that serves to support a canopy of an external pvc corridor.
I would like to realize it so that it was parametric so that it could then reuse it.
I've tried a lot of times, but I haven't done it, let's say I can't make it as parametric as I want.
the parameters I would like to have are the radius of curvature (inside or outside) the section of the tube(h,b and thickness) and then the two angles to define the beginning and end of the tube (alpha and beta in the image).
what family do you recommend me to leave? use a route extrusion? can you parameterize the arc path?
I also attached an image
I thank everyone who can help me
Good day
Good day
