architrion - conversion dao file - dxf
  • Thread starter Thread starter Italo17
Italo17
Good day to all,
When I have water in my throat, I'll be alive...
I have been working with revit for several years, but first I used architrion, simpler and intuitive, but, perhaps for this reason, abandoned by the distribution company.
in pennies I find myself having to reexhume the "dao" files that came out from architrion and have to convert them to dxf or dwg.
simple, there is the appropriate command!
Yes, however, besides not having the installed software anymore, I threw away all the architrion discs (if I think about how pissed I was for losing years of apprenticeship) and I only have the dao files because of that only job at its time I had not done the conversion.
Is there any system to read them? ?
alternative: retype the project from the attached and connected paper??? ?
(some of you still went to kindergarten, it was about 1990, so I do not have much hope ...)
greetings and thanks for hospitality,
Italy
hi italo17,
architrion:eek: goose skin, how many bad memories!
software house that changed like weather:angry:
and then goodbye and thank you for buying and spending a capital!
I still have the giant package but I don't even know
how and on which pc to install it.. . .
I'm sorry, I hope you've solved this.
hi anchorage,
thank you for the answer, in the meantime I recalcated the files, but some table went however lost.
I still have an old pc with windows 95 or 98, maybe you could reinstall the toad; what version was your ? it seems to me that the last were 6.3 of the gimeor or down of there.
However, the windows also read the previous ones.
If you care, we hear you,
Hello.it
I went to discard the intrigued archive. ...
our was a 6.43 version for Apple hardware
of bagh technologies.
the bad or good news (depending on the point of view)
is that there is no way to find the installation disks.
Thank you for your concern, now that I thought about it, too, 6.43. black floppy branded bagh, purchased from a noale company (ve) where I had also made a very useful course.
to me the program worked egregiously and I went also to daughters valdarno to make an internship at the ideaesse, that now, obviously no longer exists. revit in comparison is a pachiderma with loose reflections.
I live near madonna of sampling and I look forward to coming summer!
Italo.
hi, a few years ago they told me very well about architrion, having practically disappeared I never tried it, I was curious, pity that you lost the installation records, if you found them you would let me know.....
ho trovato questo, se può servire:
***if you are able to open the architrion drawing in architrion, be sure to smash all accessories and text to line segments and arcs since the fonts will not transfer in proper size. it is your decision whether to do the same with the dimensions. sometimes this will allow "live" dimensions to be transferred w/ .dxf to the acad .dwg format, sometimes not. if not, smash the dimensions to text, then smash the text to line segments. probably a good idea to have all dimensions on a separate layer...
