as it generates request code inventor
  • Thread starter Thread starter design77
design77
I would like to know how to generate the inventor request code, use the pc name and the pc registration number and name?
as never changes from time to time, even if the system restore cd and pc are the same.
how does it generate the code?
but what do you need to know how to generate the request code? if the product is original you just follow the registration procedure to get new codes. if you reply that you have already reached the maximum number of activations contact your dealer who will make request to the autodesk adducing the motivation of hardware change.
Then I doubt they will tell you, it's a bit like asking the banker to give you the combination of the safe :smile: Since it varies every time it probably follows some particular algorithm and I don't even think operators know it.
vabbè, however you can skip the dealer passage and request directly to autodesk. Of course, you must always specify why, but they release activation without problems.
