assemble screws and screws
  • Thread starter Thread starter iron72
iron72
Hello.
When I assemble a screw to a mother-vite hole of the same nominal diameter and of the same threading step, and then I do "interference analogy" it gives me that between the screw and the mother-vite there is an interference error signaling it with red color.
I wanted to understand if it is possible to assemble a screw and a screw-driver so that the threads of both coincide as if it were concretely screwed, so that even in the interference analysis give me ok.
the interference that marks you is that due to the threads for that signals the interference even if the screw is assembled well.the only way to remove the screw, that I know, is to go on the screw in the browser, dx-->abilita.in this way exclude the screw from the analysis only that you exclude it totally for which eventual interferences outside the threaded stem can not tell me if I am commanded.
Is there any other way? ? ?
hi iron,
but how did you draw the threads, use the special command that creates the cosmetic thread or have you created the actual thread by making a helical excavation on the screw stem?
I've never met this problem... even if it's not the end of the problem because the analysis of interference is useful to understand where the pieces are interconnected... if you know already that lives and mothers are ok then you should not worry so much, no?
Hello cesius79.
the filettarura is cosmetic, I am looking for this solution to this problem to see how the head of a screw stands once the screw has been all or partly screwed.
I know that if the combination of mother-life lives is right I do not care about anything about the analysis, and then it is also my small meticulousness in the time it advances in a project.
