assemblies advance steel
  • Thread starter Thread starter Putrella
Putrella
good morning to all....as from title I have a question on as especially in reference to the assemblies. I realized that workshop connections make the software recognize an assembled element, but why the metal scales (i.e. the two thighs) are put in the same assembly even if different and connected only by the bolted steps?
I hope someone can help me!! !
you will not believe us but I have found the solution... I ask myself the question and I give the answer... I write in case it was useful to someone..just impose, in the definition of the steps, that the bolted joint will be realized in the yard... all here...
Hi, putrella.
all software for metal structures reason in this way.
connections can be workshop or yard.
As a rule, welds are carried out in the workshop and contribute to the creation of assembled brands while bolts are delegated to the construction site.
but it is not excluded that you may need in some case to bolt the braces in the workshop (therefore assembled brand) and/or insert a yard welding.
