aerox
hi to all, finally after many hours and advice of freddygol I managed to shape what I needed!soever I tried to assemble everything, leaving no bond of freedom to the system and here we are.
Now I would like to make sure that the system can move if I move it with the mouse but something does not return to me, perhaps because I do not know how to use the multplo link.(or quaklche other option I did not understand)
I have a fixed piece to which another piece is connected that can rotate around a axis (through the action of a piston that is not designed for now.
on this piece that rotates is anchored a spherical snout (pallin to understand us), to the spherical joint collect a rod , then another rod is concentric to that of before (it would be a guide) and to the ecremite there is another connection by means of spherical snout. in the end the ball is connected to a hook which is bound on a fixed body. in practice the rotation of the raddle moves this kinematic chain and move in angular way the jaw.
doing all the links to the last step I can not take the connection between the two entities (ball on the raddle) and I assume that this does not happen because the system does not automatically allow a change of displacement/angle to the various bodies (made of gdl) so as to rest on a position that allows coupling
Any ideas?
Thank you
Any ideas?
Thank you
