[assembly] hide in the upper level
cacciatorino
I'm trying to explain a function that I'd need, it's harder to explain to her than to do it, so let's see if I can.
Let's have a car like this:
machine (top-level assemblies)
|-> base group (including frame)
|-> semi-finished load group
|- > finite waste group
to compose the axieme of the semi-finished load group, first I will insert in the axieme the component "frame", which is inserted in the separate of the base group (for which I will disconnect the box in order not to make it appear in separate of the group that I am assembling) in order to use it simply as a mounting template, then on it I will mount all other components of the semi-finished load group. I will have the advantage that changes on the frame will immediately reflect in the group in question.
Now I would like that automatically, when I insert the semi-finished load group into the upper-level "machine" axieme, the chassis component is hidden when they are inside the upper axieme, while instead it turns visible if I open the semi-finished load group in change.
I saw that I could hide the component even at the lower group level, but then I wouldn't see it at the table of the group, where instead I would like to have it, even if out of the stand and displayed in the dotted line, so that those who have to mount the group will be facilitated.
I had thought of making two configurations but I didn't know if with that tool I can handle the simple display of a component, then I might prefer not to take risks of having two different assemblies until I become practical.
I hope I was clear in the question.
