assembly of parts
  • Thread starter Thread starter enzop805
enzop805
Hello.
I'm a new proe caty user,
I would like to know if it is possible to ensure that a multi-part assembly can become one part.
I explain I am building an engine shaft consisting of 8 equal parts (handle + barbell). I thought of drawing one and assembling it with the others and then extracting the tree that will obviously be finished.
as p
Can I do this?
thanks to the attention:finger:
p.s.: with proe it is possible to extrapolate the outer surface of everything and then solidify it :tongue:.
Hello.
Bye.
under the tool menu you find "genera catpart da product" with which you can ensure that all components of a set are in one catpart.
another question,
if I have to subtract a solid :
Like a soul or something I can use?
you can use the group of the boolean together you find them in the "Feed of Together" bar, both for the sum and the subtraction
However, in addition to what has recommended Tiv there is also the command of "association" always present in the toolbar of "feaure together".
I tried to change my design and noticed that the part used with that methodology is not updated.
In the sense I have changed a dimension and it has not been updated in all parts I have made some mistakes or is it so?
from v5r19 there is the new command that allows to maintain the connection with the original. so you guarantee the original changes.
Hello, I would have the same doubt as enzo ma on solidworks.
how do I paste or subtract two parts of a single axis so that they are a single piece?
