assembly
  • Thread starter Thread starter emanuelemarzo
emanuelemarzo
Good morning, everyone.
I'm starting to use caia seriously for work only this year. I would like to ask if you can insert multiple elements simultaneously. I better explain: I have a frame and a cover with holes in which to insert washer nut and screws. Do I have to put all parts in one by one? 20 screws 20 washers and 20 bolts. When will I end?! thank you if someone can help me
uses the matrix function in the catpart for the creation of holes.
Afterwards in the catproduct you will be able to take advantage of the insertion through the appropriate works.
search the forum
Good morning.
I always have the usual problem (this time I attach a photo). I must insert 16 pins. distances as from attached file. is there no way to insert them all once?I insert the first, to insert the second currently I make insert part with bond and put a bond of superfice; After that I put an offset bond with the other pin and then a offset bond with the pan..practically so doing takes me away a three-quarters of an hour. Is there a faster way? Thank you.
Good morning.
