assi in pro/piping
  • Thread starter Thread starter AMinati
AMinati
I can't remove the axes from the axis designs generated with the pro/piping module. remain in sight even though theoretically hidden from other parts making over heavy all views. in the help you try to set a configuration variable, but nothing changes.
Any suggestions?
aminati
I go to memory: Try to put the tubes on a layer and then turn it off.
Does it work?
solved, in addition to setting the variable relative to the general configuration file, you also need to set the corresponding variable in the table drawing options!
Thank you
aminati
