assieme solidworks da step
  • Thread starter Thread starter Dario Carozzi
but once it worked well while it is since 2018 as a version (if not erro) that the imported steps no longer open them so that the parts are visible!
practically the parts at single file level are not there. Once, a step of a set was imported and when you saved it, in the rescue folder of the axieme in sw format, the files of the parts were also found. Today this function seems to be gone.
I before inserting a step into my set, convert the step into a single part or together if I need the distinct parts, only after I integrate everything into my final or partial assembly
it does when it is active active active il 3dinterconnect.
found! but I at this point to have the files parts, must keep it activated or not, thank you!
