assign automatic encumbrance measurements on separate
  • Thread starter Thread starter cerbonim
cerbonim
I would like to assign the automatic measurements of the piece in the separate section, is it possible?
on modification properties component there is
You can do it if you can go under:
tools->info-analysis->size
select the component, and get the size along the 3 axes.dimensioni_td.webpIf you want something automated, you can always use the old gpl or a plugin as you ask.
soon,
Matteo
Thank you, matteo, but I needed it directly in my mind so I don't have to recompile it by hand, thank you.
