associate a table with the part.
deep70
Hello everyone,
I wanted to ask you the most correct methodology to associate a table with a set or part, I explain better, I have a right welded with relative table, now its symmetric or mirrored sx differs only for a change of positioning in a plate, I would like to be able to use the already made table of the welded dx and connect it to the welded model sx, without having to remake the table completely, how can I do?
Thank you as always all in advance for the kind answers given.
Good evening, everyone.
You can't do that.
only a careful flow of welded modeling can bring you closer to a more or less complete result.
if then the symmetrical realizes it with the symmetrical derivation commands, well, prepare to requote everything.
to tell the truth I managed, just change the name temporarily to the model to which it refers, open the table and redirect it to the 3d wanted, then rename correctly the original 3d.
without doing that round you can copy the table, open it and use the command "replace model reference".
All right, but if you write it's symmetric, it's another thing.
There are many people who use the automatism of the mirroring because very quick, obviously you used a more correct method, which then just moved a plate from right to left.
in which case, the command indicated by technomodel, is the correct one.
until they entered it, I do not remember in what rel., the method of masking was the only one that allowed magic.
thank you so much technomodel, but where do I find the command?
I don't remember, I don't use inventor anymore.
Try to spray in the various tabs, you should find it.
or with the search, or the online guide.
Hello everyone,
I wanted to reconnect to this discussion and ask you: is it possible to associate a table with a part? I explain better: I have a set with his table, the customer wanted for his needs to transform that assieme into a part, so it is no longer an asm file but becomes a part file. is it possible now to associate the old table created by the axieme to the part file? without having to do so?
thanks many to all for any given answers and good day.
