association formulas a comment manufacturing
  • Thread starter Thread starter Micheletecnospazio
Micheletecnospazio
Hello, everyone. as usual in this period I address experts to clarify some ideas
this time the question is... made the model with the cad then made the part with the cam in manufacturing and post processed everything ok...
Now something changes in the model
then automatically changes in the cam
only one thing does not change the comments of the cam that do not point to formulas like quotas
I make an example if I have to fresare a diameter that before was a diameter of attention say 1000, now this diameter has become 1010.. the comment that is near is milling plan of diameter 1000 and does not update as the quota that is linked to the formula.. .
how to tie comment to the formula?
thanks now for your answers... I hope I was clear in the description of the question... :biggrin:
Unfortunately I don't know the cam, but what you want to do maybe you do with pmi
I believe it refers to the words that are made appear in the postprocessed file to feed the cnc of the machine.
Or am I wrong?
exact ip design..
matrix I did not understand what your proposed solution is...:biggrin: as usual I make you write things 10 times
I don't think there is the way, that is descriptive texts of the user, I doubt you can dynamically associate them with a variable .
exact ip design..
erase everything.
I didn't realize this was about the measurements in the post-processed file.
I thought they were labels on the model.
Sorry.
ps. pmi are the "product manufacturing information", i.e. the characteristics of the model (matrial, notes, tolerances, control points, quality points, etc.).
If, for example, you put on a plane the "label" tolerance h7 for example, the cam, properly educated, can automatically create a cycle that includes roughing/semifinishing/finishing.
If you put a wide tolerance or just don't put it, you will create a normal click of roughness for example.
are the new frontier of automation cad>cam.
in nx you can find them in a special pmi menu after activating the application with start/pmi
I had found the literal meaning intrigued by the acronym but I didn't realize it was such an automation... ... the new frontier... save 3\4 time... without exaggerating... I have to try it when I get back to work. is it just an additional package?
Do we try everything (obviously overmetal finishing cycles etc. will have settable machining overmetals? also in a variable way. . )
for the question of departure instead there are no totem solutions of nx?:biggrin::biggrin:
