attributed as a nested block?
  • Thread starter Thread starter 77marco77
77marco77
I find myself with many blocks that contain an attribute (tag) that is actually a block (a$d...). even opening the editor and trying to explode the tag/block I can't explode it. Can you do something?
Thanks for the answer.
If so, I have no idea how to behave. . .
Maybe if you can take a look at him.
in the block of the attached file I do not find any attribute "tag" and no nested block is contained
In the meantime, thanks tristan, if you are there, we will definitely arrive at the solution.
if I open the design and give the command "elimina" I find among the undeleteable blocks a block named a$c76a5c4db.. .
This block is in all the blocks I have in the library. if I make a wblock I find the block between those exported and it turns out to be the tag fabrikat
I had no problem in exploring the nested block with the fabrikat tag, you have to do it from within the editor and it is not set as unexploding.
Maybe your problem is to remove it from the definition of all the blocks, not to explode it.
thanks reddish, your comment made me reflect!
with this delete blocks | lee macdentI could remove the block from all blocks (delete), I was afraid I had to put back (add again) tag to all blocks but it seems that the tag remained there...
I would say problem solved!
