auto print areas within the model
  • Thread starter Thread starter Tekkasoft
Tekkasoft
is the first time I write in this forum so you forgive inexperience in communication. ....
I would like to know if there is a way to set up and then automatically print the classic areas contained within an autocad model.
I explain better, typically in the template page you draw many a4 sheets that contain patterns, drawings and more. when printing them you can choose
which sheet print one at a time.
Is there a way to set it up for everyone and launch an automatic print command for all sheets contained in the model? ? ?
an early thanks to the solution of the problem
you should use a macro linked to layout. to understand how they work both one and the other uses thehelp
oppur creare uno script con l'utilia di rpor66 "cappilet.xls" that you print the page settings created for each a4 via the command:
plot
printing area -> window
set page -> add
I attach an example, you must clearly replace the names of "page setting" and those of " .pc3 files"
