autocad 2013 crashes when booting
  • Thread starter Thread starter RAGHEB
RAGHEB
I have acqistato a pc with processor i7 2670 qm with video card amd radeon hd7670, I have installed autocad 2013 , the installation has been completed but 'at the start of the program is blocked and does not reece to open the file dwt after which' closes ; I tried to format the disk and reistpull professional w7 but it gives me the same error Can someone give me advice?
Hello, is this the first time you install autocad 2013 on a car or you installed it on the old pc? If you have any way to install it on another pc and verify its integrity? Do you have an original license? If so, you are entitled to technical support by autodesk.
ps. do not write in case :)
I installed a trial version downloaded from the autodesk site; I also installed inventor 2013
and it works correctly except when I try to put on the table the stem of a folded sheet, in this case it freezes and comes out from the program;
try to disable aero on windows.
Yours is a notebook, reading the name of the processor, not a pc.
It's good to point out, there's a big difference, even if it doesn't seem, at the driver level.
bye
you're right is a laptop, I tried to disable aero but it doesn't open, it gives me the message load library failed with error 126 impossible to find the module specified after which' closes, yet the installation seems to go to good end
is a problem of the graphics card drivers.. there is a procedure to follow, copy and rename a file. find the video that explains it to youtube. .
I tried but it's not the same, I'll contact the acer service center or the autodesk support, thanks anyway
Strange.. I had the same problem and I solved it so .. you restarted, didn't you? Otherwise you could try to change the drivers and try to use a slightly older version
I've done it all over again and now it works, probably I've made a few passes wrong.
