autocad 2015 - news
PlannerRoad
e' ithe betatest phase of autocad 2015 with the new codename autocad longbow.
first noises and certainties of ever, 605 euros to update the software with four phenomenal minkeys to "velocize" the job, practically while you think autocad has already done everything.
for charity, in every version there is always something useful, but, precisely, something.
if at least the bribe paid every two years (as once) the grades would be 45/50, not exactly 90. :mad:
I personally think that autocad is part of a “generation” of programs that has exhausted its development limit. you can improve some fiocchetto, but nothing substantial.
who wants to go further must change “generation” or switch to parametric programs revit or inventor, staying in autodesk house.
But people are prepared to modernize themselves for costs and also for laziness. so autodesk can not stop releasing new versions of the program that made it famous. He would lose a consistent part of his own income.
Therefore, in my opinion, it continues to release new versions even if free of content. if then people continue to sneak out for a software outdated they are cabbage. On the other hand the autodesk sells autocad to about 4'900 euros, with 5'000 affre una suitte con revit, autocad detailing, autocad and more. everyone saves 100 euros as he believes.
with annual subscriptions you save a lot compared to a new revit license, I can understand. everyone spends as he thinks.
It's the usual story, the slogan of the autodesk is "increasing productivity." refrain that I hear from autocad 13 (not 2013!)
But people are prepared to modernize themselves for costs and also for laziness. so autodesk can't stop to release new versions of the program that made it famous. He would lose a consistent part of his own income.
autodesk is not that can not stop, He doesn't want Stop. And why would he pull the chicken's neck from the golden eggs? autocad has now arrived at the end of the line and, apart from some gadgets or small improvements released with the dropper, autodesk in terms of development imho costs him a whistle. sells old stuff at the price of the new one, updates and subscriptions are a robbery worse than 5000 € that serve to buy autocad, customers despite this run behind them; better than that!
and instead something substantial can still do it, indeed, they have to do it.
an existing problem always in the autocad, are the restraints. instead of getting lost in phantasmic 3d, 4d, etc... it would be the case to review once and for all the operation of the restraints. and never possible that I click within a definitely closed area and that the answer is most of the times negative and therefore does not do me the restraint? also the hpgaptol variable is as if it did not exist. less strains and proclaims on "increasing productivity" and more attention to the simplest commands, used, among other things, very often.
:36_1_1:
great......... and I add this to us:
[video=youtube;bgrsArkczl0]http://www.youtube.com/watch?v=bgrsarkczl0[/video]beautiful blue ball.......
ciauz
the beta phase is finished.
on 27 March the bond for the non-divulgation of betatesters expires.
Well... you are right, but the fact is that the new version of the cad allows you to open new files.
in my study for example there are 4 cad lt 2009 and you work perfectly, only I have the 2014 full cad, but for the simple fact (as well as for the very useful pdf import) that we can open the dwg files of new versions coming from outside.
However, this revit story mentioned a few more posts on it made me reflect. I'm going to take a look, because if revit allows you to do the same things that the autocad does it could be a controlled migration start. . ;)
to export pdf there are virtual printers. 1 pass (print)
export to pdf from autocad layout? 12 steps and 1 nervous :d
I will not be an expert in autocad, but as far as I am concerned with this latest version is shameful... but seen so little more than the previous version since I use this software (and less bad than as a student I do not have to buy it).
was a miracle to start it (case nvitix.dll error) also just started I find that hardware acceleration is disabled! I am not given the opportunity to change this approach. autocad in fact reads me as a primary video card the intel hd without counting the presence of a nvidia. the beautiful is that autodesk and nvidia are in combutta for the development of the software. Good result! the error in startup is given by nvidia and exceeded that I can not even choose the video card without passing from the bios...(which I haven't tried yet)...bah! what to say...compliments
my modest opinion. .
Well, we have a darker theme... a new selection "lasso", graphic improvements like transparencies and other small thighs in the mtext command (which therefore wants the enabled hw acceleration) antialiasing 2d activable/unactivable via sysvar, active command icons near the cursor, enable-unable. . .
and the layers are now sorted in the list with their natural order (1,2,3...11,12 instead of 1,11,2...)
but:
if to the 2010 version someone had come to ask me if I needed some specific features, I would certainly have responded no (except for improving stability and efficiency, which from 2010 to 2014 is clearly improved)
in 2015 we have however all that series of side tools type autocad 360, autocad recap, and now also a standalone app manager, that helps us install/disinstall besides features and add-on, also the other autodesk home products.
in practice they are implementing, improving, and pushing to use the tools that I personally have never used, nor have I ever seen to use.
attention, not for this however are to be considered useless. autocad is an enterprise-class "master", does not listen to the drawing of the dittucola that uses ć.ǎ.âț..
not by chance in fact, and here I end, with this latest version have introduced some improvements even in the licensing, I have read -without however deepening much - that you can choose from the package, the features that you want to use, even temporarily, "build" the desired combination
update after a few days of proof of the definitive version of autocad 2015:
bad, bad.. Bad.
We're not here.
they weighed everything down, introducing a lot of useless stuff, like a "start page" where to select the recent files. . .
One click less..... but many more seconds in which the pc remains packed to load all the contents of said pages.
icons and tooltip everywhere, ok, disabled.... but the impact is really annoying.
In addition,
fatal lack:
the classic autocad interface. They really did. I only use that because the ribbon-style can not see/use.. I can't. .
I found the way to export the classic interface from autocad installation 2014 (pazzia!)
We're not here. hold tight the old versions -for now-
startup = 0 and solve the problem
turn them off. . .
In addition,
fatal lack:
but come on, we return to change gear with the double...pathetic
We're not here. hold tight old versions
do it yourself; I go well with 2015
of course the above opinions are strictly personal and refer to the application "out of the box" or just installed and without having yet put hand.
as Tristan suggests, that even judges pathetic the classic interface that I like so much, everything is widely customizable.
question. .
introduced the purchase of 2015 with monthly/annual license. if I do the annual one, then do I have the opportunity to pass eventually to autocad 2016/2017 and so on?
if you make the annual subscription in March when it comes out 2016 you can obviously install it
Staff online
