but I have a doubt: I opened an old design where the circles saw themselves as octagons and set the command viewris putting it at a very low value (5). all octagons have become curved. What's the story? I thought the number indicated how many segments to use to make the curve!by memory:
is a value linked to the single file. for the old there is no solution, for the new you have to save it in the dwt
thanks for the explanation. what do you recommend setting by default? take into account that I work mainly on single pieces, max axle from a dozen piecesNo. It is a value that indicates how the arches and circles must be approximated to speed up rigen operations, at the expense of visualization.
if in the dwg is represented the hole of a bolt of a wheel and you are looking at the whole car, in fact this hole will always be represented as a dot, whether accuracy is 5 and 20000.
If you zoom in on the wheel you will see polygonal (with accuracy 5) or circular (with accuracy 20000).
but if you see it polygonal, and give a rigen, you will see the hole again circulate, except then having to remake a rigen if you want to review the whole car.
was a parameter linked more than anything to the computing power of the old video/processor cards, when to make a regeneration it took a nap of time.
Okay.I'd set it up at 20000. modern machines have no problems with long regeneration times.
