autocad and pdf creator: problem file name length pdf
  • Thread starter Thread starter pertengineering
pertengineering
Good morning, everyone.
I have a problem with pdf creator version 2.1.2:
when I create pdfs from autocad dwg files, the pdf file name shows all the address of the folder where the file is placed.
trying to cuff in various forums, I found that you have to change the tokens in the "profile settings".
by default, in document, Title and author modelsYou Title, is put <printjobname></printjobname>while in SaveYou file name, is put <title></title>.
if I change the values of the first variable, putting <inputfilename></inputfilename>, I no longer see the whole address, but the file name is not complete.
specific, that the names of the dwg files we create contain the characters " . - _ + " (not the quotes).
for example, having a design with numbering: 1.245-002.03_045.01.dwg is saved in pdf format by the name 1.245-002.03_045.pdf.
He misses the last part of the code ".01".
Similarly, for other types of documents, we have another code:
the file 1234-g12.04-h000_sh1.dwg is saved under the name 1234-g12.pdf.
I don't understand why the pdf file is not saved with the same name as the dwg file.
Can anyone help me?
Thank you in advance
